Is it a sensor bad or..?
Old 05-11-2006, 08:00 PM
  #26
jfairladyz's Avatar
you need to verify that you're not losing fuel pressure. Take taht pump back and use the money to get a fuel pressure gauge. And no, it wont cost as much as the pump did
jfairladyz is offline
Old 05-11-2006, 08:11 PM
  #27
what about the ic module, the one on the side of the dizzy, if it wanrms up and is weak, it will cause similar symptoms, maybe the coil? thats far out there but maybe, ive had cars at work do that, and it was the coil, gotta spare?
SHADY280 is offline
Old 05-11-2006, 08:19 PM
  #28
jfairladyz's Avatar
I was going to say coil too but if it were a weak coil then giving it gas should only make the symptoms worse wouldn't it?
Old 05-13-2006, 11:15 AM
  #29
n00blar's Avatar
Ok, I think I finally fixed the issue!!!
I replaced three things:
1. The EGR valve.
2. Some vacuum hoses around the EGR valve; I got some new ones.
3. The cylinder head temperature sensor was replaced also.
My ZX idled for about 20 minutes without losing power and shutting off.
Thanks for all the suggestions...you guys are awesome!!!
n00blar is offline
Old 05-13-2006, 05:33 PM
  #30
jfairladyz's Avatar
congrats.
Old 05-13-2006, 05:47 PM
  #31
lotta peolpe having the same probs latley here, all related to the same things, good to here its fixed, just seems to be a wave, solved by the same stuff it seems. mine too hahaha
SHADY280 is offline
nick731
05-08-2012 07:38 AM
jaredjmoore89
11-29-2008 08:09 PM
thxone
06-18-2006 04:29 PM
Seraphic
15
07-13-2005 09:22 PM
DallasZ_388
12-03-2004 06:00 AM
Quick Reply: Is it a sensor bad or..?
