six speed tranny?
six speed tranny?
Is there a 6 speed trans out there that will bolt up to the l28e? I have an 82 280zx na and I feel like I need the extra gear for highway travel. I will be doing the speed limit, which is 70, and my tach reads 4k rpm. If there isn't a 6 speed that will work, then how can I lower my rpm on the highway?
Hey, just lurking for this post - but 4K seems high for 5th gear at 70MPH. I have little to no experience with 280s. I think my Z31 does 70MPH at under 3K, could be wrong....
(Edit: Just checked it out today. My '86T does a steady 70 at 2600 RPM.)
So my question is did you switch something out or was your 280 factory-geared to run that high - in 5th? Thanks for the info!
Thought so, Evan. So Hunter, am wondering if your tachometer/cable set-up is out of whack. Even if your exhaust is 100% good - that Z would probably seem to be screaming at 4K. So, are you sure about the cause of your RPM-tachometer problem?
(Very cool link below, Nismo!)
Yep, at 70 in 5th my '82 is just below 3k. At 3k it's between 75-80. So I would agree that 100 would be 4k. Of course my needle is a little loose causing it to jump all over, so I use my K.I.T.T. speedometer app and it works quite well.
