So I powdercoated the Z..
Finally got just a tiny bit of snow where I live here in California.. it's been quite the dry winter.
As for an update, it looks like my Z might finally be hitting the streets! Got a letter back from the previous previous owner giving me a bill of sale from him to the guy I bought it from. Registration can be a pain in the *** if the guy who sells you the car never legally owned it. Now I just have to hope the DMV will accept all my paperwork.
Silly Z Drivers... Z's don't belong in the snow!
Is a bill of sale required in addition to the signed title?
I do this all the time with cars I fix and flip. I never legally own them, I just have the prev owner sign the title, and when I sell it, the title is ready to go to the DMV. In Utah, the back of the title with the signatures IS the bill of sale.
Unfortunately now the only way you can claim it as a gift if it's from an immediate family member...and if you write a bill of sale for $1 they now have a minimum set tax they can hit you with that may actually be more
At least here in Corpus Christi...and yeah...most inspectors here don't even check to see if you have an exhaust system...as long as it drives in, lights work, and it stops...then it's safe
Well I got a a title transfer and application for a replacement title paperwork. But of course the guy who sold it to me never technically owned it, so I had to get a copy of the bill of sale from previous owner to the guy who I bought it from.
This is the first car I've ever attempted buying and I've learned from my mistake haha
Oh, and I fixed that mystery fuel leak too! Starts up like a champ.
Bad news.. turns out I didn't fix whatever is causing my car to lose fuel pressure. I don't see any leaks in the spot I just replaced lines and where the leak was before.
Can anyone think of any reason why my car loses fuel pressure? I runs fine once I cycle the pump for a while.
I have already replaced the FPR and I hope the one I bought wasn't faulty also though I kinda doubt that.
How fast does it lose pressure? 1min? 5min? Overnight?
Leaking injector? Have you pulled the spark plugs after the pressure has dropped, but before starting it, to see if the injectors are leaking?
Have you tried pinching off the return line after the FPR to see if it holds?
Someone mentioned to me it could be the fuel pump valves(?) releasing the pressure, or the small filter back by the fuel pump also.
Looks like Saturday or Sunday will be the only days I can work on my car and hopefully I'll get some news about my diff tomorrow..
When I removed the axles, on one side the end of the stub side popped off (a spring and the bearings inside and a little gasket). Do I need to worry about this? The gasket isn't very flat so I wasn't sure if I should replace it or just stick it back on there.
Is there any other maintenance or things I should check while it's off?
Also one of the CB boots is torn a bit, I assume it's probably a good idea to replace that.
Edit: Oh and I am borrowing a fuel pressure gauge from a friend of mine so maybe I'll find out what's up with my fuel system this weekend also!
I figure with a pressure loss that steep we'd see fuel leaking out right? Well as far as I can far as I can tell there is none. That leads me to think that it could be the fuel pump valves(?) that I asked about before. Also this time when I was cycling the pump, a few times the fuel pump would just stay on indefinitely until I turned the key off.
Any ideas and/or pointers?
