Somebody please help me
So my ignition locked up the other night and the key was stuck in the position right before you turn to crank it so i had constant ignition power flowing for a few hours and when i got it all fixed i charged up the battery and tryed to start it but no spark at all.Im guessing i fried something letting that constant power hit for so long because it was running perfectly before hand.Any one have any advice on what could of happened?
________
Prilosec Problems
________
Prilosec Problems
Well it definately drained my battery but now i have no spark so something happened.what can i do to test the different parts of my ignition to figure it out.could the fact the key got stuck mean something in my ignition switch is bad and thats why it wont start
You say you have no spark, but i just want to clarify its turning over right??
Yeah it turns over fine but thats all it does it doesnt even start to sound like its gonna fire up at all.I also put a crane cams optical ignition module on it so any chance it could of fried?
________
LovelyWendie
________
LovelyWendie
Have your battery tested, or, if it's a manual, see if it'll push start. I have an 82 280ZX and periodically I would have to push-start it. The motor turned over fairly quick, but it wouldn't start. I had the battery tested, and it only had 80 cranking amps. The battery that was in it was supposed to put out about 800 cranking amps. New battery and presto! Starts instantly every time.
The only way I ever got it to start with the old battery, other than pushing, was jumping it off my mom's Expedition. It had a big battery and a big engine. Now that I think of it, I did start it off a Ford Ranger, but the guy had to keep the motor at a fairly high rev before the car started.
--Ryan
--Ryan
Well my z is running great again turns out my coil and main voltage wire were both fried so put a blaster 2 coil and new wires and fired right up
________
Johnny claes
________
Johnny claes
