speaker sizes
Old 05-22-2003 | 04:27 PM
futureZowner's Avatar
speaker sizes
Hey,
I recently purchased a '79 280ZX 2-seater and would like to update the stereo a little bit. I need to know what size speakers fit in the dash for a '79 model and what size speakers fit nicely (no cutting or anything) in the speaker mounts behind the seats? Thanks in advance for the info.
Old 05-22-2003 | 04:50 PM
icice9's Avatar
Super Siver & Black Stud
im not sure but i think its a 4" speaker
Old 05-22-2003 | 10:25 PM
Skully's Avatar
yup 4"
Old 05-23-2003 | 12:13 AM
rear speakers....?
ok ok, 4" speakers in the front....but what size fits best in the mounts behind the seats? thanks.
Old 05-23-2003 | 01:23 AM
icice9's Avatar
those are 4" too
Old 07-21-2012 | 09:24 AM
Male's Avatar
So 4" for the 2 in the dash?
Old 07-21-2012 | 11:14 AM
evandubya's Avatar
Primer Grey FTW!
I'm pretty sure the ones behind the seat are 6".
Old 07-21-2012 | 11:23 AM
4" for the dash and the stock rears are 5 1/4" but 6 1/2" will fit without cutting - just need to change the screw holes.
Old 07-21-2012 | 01:29 PM
Male's Avatar
On a 79? Mine look like 4"
Old 07-21-2012 | 03:25 PM
4" in the front - rears are stock 5 1/4 but 6 1/2 will fit
Old 07-21-2012 | 07:18 PM
Male's Avatar
one question how the hell do you take this one off?
Old 07-21-2012 | 08:04 PM
evandubya's Avatar
Primer Grey FTW!
You have to pull the whole dash out!!!!
Old 07-22-2012 | 09:00 AM
Male's Avatar
Realy?!
Old 07-22-2012 | 09:34 AM
evandubya's Avatar
Primer Grey FTW!
Yep, the screws are on the under side and all the ducting and heater box is in the way.
Old 07-22-2012 | 02:20 PM
Male's Avatar
Well that sucks and the other on is just remove the glove box right?
Old 07-22-2012 | 02:56 PM
evandubya's Avatar
Primer Grey FTW!
I just looked at my 79 dash. If you are rather dexterous, you might be able to reach the center speaker with a small no. 2 phillips screwdriver if you, pull the glove box, remove the center gauges and the ducting, but it would be quite a stretch. Good luck.
Old 07-22-2012 | 04:05 PM
Haha good luck!
Pull the dash and replace all the foam in your ducting and wash it all in the sink while you're in there. Makes a big difference for your air flow from the vents.
Old 07-23-2012 | 01:45 AM
duckyz's Avatar
You can get some tin snips and make cut outs for 6x9s behind the seats. Trying to figure out where to fit some 6.5" in the front...
Old 07-23-2012 | 03:27 AM
1980zx's Avatar
get some shallow 4" speakers and make some custom kick panels for the floorboard. Its way easier then removing the dash. Or what you could do is just put some 1" tweeters on the front kick panels and two 6x9 in boxes in the back. Thats what I did with 2 10" subs- Sounds great
Old 07-23-2012 | 07:51 AM
Male's Avatar
Ok when taking out the dash is there any way posible that I can put the streeing wheel rong because that's my biggest consern not trying to go of topic
Old 07-23-2012 | 11:40 AM
evandubya's Avatar
Primer Grey FTW!
Just make sure the tires are straight, take off steering wheel, don't turn tires, put steering wheel back on when finished.
Old 07-26-2012 | 02:54 PM
Male's Avatar
well mine are 4" all around if you want to keep the oem speaker covers for the rear and you could fit 61/2 without cutting behind the seats?
alfradrod
04-15-2006 10:03 AM
DavidWann
12-02-2003 04:21 PM
ex247
05-08-2002 05:32 AM
Craig_Paterson
03-29-2002 06:45 AM
81Datsun280ZX
02-19-2002 11:18 AM
