Starting problems when engine is warm!!..help
Old 04-01-2011 | 08:28 PM
Greg79's Avatar
i have a 1979 ZX .. starting up in the morning (no problem!).....starting when hot ( PROBLEM! )...it sounds like its choking out , then runs rough....gas mileage sucks!!...help me out?
Old 04-01-2011 | 09:21 PM
Welcome to ZDriver!
I suggest starting w/ the basics...
Read the spark plug tips... color? wet? dry? build up? Do any look different than the others?
Do a basic check over and tune up. Replacing worn out plugs, wires, cap/rotor, air filter, checking fuel pressure, running FI cleaner, will do wonders for a neglected car. Check all sensors and connections. They are prone to corrosion.
Old 04-02-2011 | 04:58 AM
check the timing it may be too retarded.
Old 04-02-2011 | 09:00 AM
skittle's Avatar
Taste My Rainbow
Also check your CSV (cold start valve) it may be leaking. When the car is warm its no longer needed so if its leaking its burning extra un-needed fuel.
Old 04-03-2011 | 05:35 PM
mrprofile's Avatar
i have the same exact problem on my 79, it runs great if i keep it on, then if I warm it up and shut it down, go away for about 30 mins then go to start it again it will idle roughly at like 400 or 500 rpm, and if you give it some gas it almost feels like it miss fires, but doesn't stall, I have tried replacing the pcv valve, the cap and rotor, ignition and none of it worked, by the way its not the O2 sensor, mainly because 79's didnt have them lol, as I came to find out. so if you find the solution please tell me! lol
Old 04-04-2011 | 09:19 AM
skittle's Avatar
Taste My Rainbow
Have you checked the gas cap, it might not be getting a good seal. Not sure if it will work or not just tossing it out there.
Abeck85
06-07-2014 07:54 AM
Sixer
05-10-2010 08:19 AM
NAIIZeater
02-19-2007 07:12 AM
Tbone
05-13-2004 11:17 PM
ZinAustin
11-01-2002 07:58 AM
Quick Reply: Starting problems when engine is warm!!..help
