Starting then OFF it goes
Okay so what the heck? Engine (L28E) starts fine, idles fine drives fine.. When it reaches normal running temp it shuts off. Can start again once cools down. Has anyone came accross this issue before? What might I check to correct this problem? 81 5spd 81,220 miles. Seems to be one issue after another with this car but I cant seem to let it go.
Read some previous threads with simular issues but mine dosent act weird till its at normal operating temp.. Has gas.. New plugs.. New wires.. New coil pack.. This sux and is getting expensive.. How can I do a diagnostic on my car? Where would I hook up?
I do not have one.. I pulled the top (out) hose on the filter once its warm (of course with the car off) and flicked the starter a couple of times, old faithful spewed up as it should.. Guess the pump still works.. Whats next..?
It might be the ignition module, that pretty little black box on the side of the distributor. i know my ignition module used to leave me stranded when it got warm now and again, that so sucked, it took me a bit to figure that one out since my car would start and run after it had cooled down. Just my opinion, hope that helps ^.^
possable oil temp sender located on the passenger side engine righ by the oil filter or ... and big or is the water temp sensor located right below the thermostate im having the same problems with my 1982 280zxt starts fine runs fine until its up to normal temp when i come to a stop dead instently im thinking its my fuel pump !
Originally Posted by GypZ_Rose
... that pretty little black box on the side of the distributor.
The water temp sensor won't shut off the car. Only the major sensors will do that (AFM, CHTS, TPS).
Have you set / checked your timing?
Have you looked for vacuum leaks?
Have you checked the AFM / CHTS / TPS connections?
would the AFM and TPS do that after the car has warmed up? i know if the AFM goes bananas then it could cause headaches, but i've always thought the TPS on these would just cause the car to not run right, not turn off entirely, then again i could be wrong (as usual ^.^).
the tps wont send the car into " death mode " as i call it it would have to be the ECU could be old or ignition module located on the front of the distrubitor cap . If the wires are taped up maybe a bad connetion eroded wires " get some eletrical tape a soldering iron and some soder " take the step unwrap your old tape and inspect the wires ! if bad ,cut, splice, solder, then wrap or " shrink wrap the exposed wires its pretty eazy honestly i had to do it to my wifes 1982 280zx n/a/
Well damn. My sight isnt the best and I cant hear worth s#@t from working around helicopters so guess I will just have to get a partnet to help me.. Or just pay Nissan a large amount to get my baby back on the road for me. I miss driving her hard, she likes to be driven hard. HAHAHA.. Kidding.; So bad.
I think you just unplug the red and green wires from the module and pull it away from that rubbery thingy it sticks into on the side of the distributor....really easy to see if you take the cap off.
