Startup Problem?
Startup Problem?
The Z died on me 3 days ago, I started it up and the rpm would go to about 1000, then decrease until it died. I could get it to start, I just had to rev the motor for a few seconds, then it would be fine. most of the time it works perfectly!
what gives?
(yes I searched)
what gives?
(yes I searched)
My NA 1981 280zx is having the same problem as you kingdatsun, did you find a solution?
I just pulled my AFM and it's perfect inside, no grime. I've already replaced the vacuum tubes.
Time to check everything else I suppose...
