Stock sway bar size?
Does anyone know what size the stock sway bar is... 22mm or 23mm?
I'm getting ready to order the Tokico Advanced Handling kit and might as well do the bushings while I'm up under there. Shox.com wants to know what size the sway bar is before I order.
I believe stock front is 7/8" rear is 3/4"
usual upgrade is just a front 1" and a rear 7/8"
Nismo still sells the front bar which is 1/18" thick.
to be honest though, if I were you, I'd only upgrade the front bar, especially if your car tends to oversteer as it is (stiffer rear bar will only worsen things)
I ordered the sway bars from MSA, powdercoated gun metal. i'd have to say when matched with poly bushings. it's a huge improvement. of course i replaced the ball joints and tie rod ends at the same time.
There really shouldn't be a reason your car understeers, what kind of tires do you have? my friend had some super shitty tires, then I let him borrow my Falken 912's and he said the car turns like it's supposed to now.
also, what suspension are you on right now? still stock stuff?
moorebl
10-08-2012 05:09 PM
roninjiro
10-04-2004 08:53 AM
