Strange Timing Problem
Old 03-12-2010 | 08:13 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
I've had an issue with timing since I got my Z.
Set my timing to about 8 degrees, rev the motor, check the timing again and I'm at 15 degrees, blip the throttle to see if the RPM's will come down a bit and I'm at 25-30 degrees. Shut the motor down, restart and I'm at 5 degrees then it slowly comes back to 8.
Engine, warm, idles at 1000-1250 RPM no matter where the idle adjuster is set.
I've replaced the distributor (a lot of play in the shaft) and all the vacuum lines last year and I've had this problem with both the old and new distributor/lines.
I've bumped the timing to about 11 degrees, or what I can assume is 11 degrees, and it's got a bit more kick to it now, but this whole timing and high idle is just got me confused...
Anyone have any suggestions on where to go next?
Old 03-12-2010 | 08:17 PM
skib's Avatar
This facepalm's for you!
what kind of shape is your crank pulley in?
have you pulled it off and looked at the rubber ring on the backside?
Old 03-12-2010 | 08:48 PM
Pulled the pulley off just before parking it for the winter to put a new timing cover gasket on and it seemed ok. The rubber was a bit dried out but there wasn't any play that I could tell. I guess it's possible that it's time to replace it.
Old 03-13-2010 | 08:30 AM
Have you tried leaving the dizzy advance unplugged from the vacuum line? Rev w/ no vacuum to the advance & that will tell you if it's the dizzy advance, or ecu.
matt31
12-16-2014 03:22 PM
casperzxt
03-01-2010 10:19 PM
kayl
02-24-2010 05:19 PM
RodMoyes
01-25-2007 05:06 AM
DODthunder
12-26-2005 08:08 PM
Quick Reply: Strange Timing Problem
