Suggestions for a aftermarket fuel pump?
Old 02-02-2005 | 07:23 PM
Heat Rave R's Avatar
Sooner or later, I'm going to get an engine swap for my '82 NA 280ZX. I want to be getting an aftermarket fuel pump that will support 300-400hp and would like some suggestions on what kind to get. I've heard of Aeromotive and Walbro pumps. I had always thought it was an in-tank pump, but I think I see it right behind the rear-right wheel. Is there a particular kind of pump (in terms of flow-rate and fitment) I need to look for? Also, anyone know some places that have good prices on em?
Old 02-02-2005 | 09:14 PM
lifegrddude's Avatar
Externally Wastegated
Walbro fuel pumps, one of them is close to a direct bolt in. Plenty of people on Hybrid use it. I think it's the GSL392 or something like that. Flows 255lph so it's good enough. If you check with Summit racing or Jegs, I'm pretty sure you'll find the pump. It's ~150 bucks.
Old 02-02-2005 | 09:17 PM
Skully's Avatar
yuppers i gota walbro 255lph fuel pump make sure you get the INLINE not INTANK one...its not in operation yet since m engine is out..but thats what i bought...
255lph walbro and aeromotive FPR
Old 03-15-2005 | 03:48 PM
fairladyVT's Avatar
Old Porche pumps work and they put out a ton of fuel pressure. YOu can even blosk off the return line and add larger lines if your injectors are strong enough to shut under the pressure.
305zx
09-04-2011 07:32 PM
sameerb1
03-20-2011 06:21 AM
MylesBlaq
07-03-2010 03:41 PM
ern
10-20-2006 08:01 AM
zryde
05-06-2003 09:46 PM
