Thinking of buying a 1981 280ZX
Re: Thinking of buying a 1981 280ZX
the most id look for is rust thats not a bad price on it mine had alota rust and still has some but i removed most of it .....i dunno look for normal stuff mechanical like you would in a normal car
Guest
Posts: n/a
Rust would be the primary thing, but I have found a few others over the last month. I found basically the same thing that you found, '82 280ZX, but it hadn't been started in 2 1/2 years, so unless you know the current owner, ask how much its been driven over the last couple years or more. Check and see if there is any sign of fuel leakage at the injectors, check fuel lines and hoses, check the oil, rear differential seal, any kind of leaks and so on, so far on mine its been the clutch, break and clutch master cylinders, clutch slave, injector insulators, and injector seals, and there will be some front end work because all the dust boots have pretty much worn away. But the price sounds pretty good and if your looking to have the fun of fixing it up, then go for it.
Jamie Shelly
kd5izq@msn.com
ICQ - 159705433
IZCC Number is #12402
Jamie Shelly
kd5izq@msn.com
ICQ - 159705433
hotrodcoupes
08-19-2011 01:41 PM
donvito33139
05-19-2006 08:46 AM
