Tranny Question
Old 02-13-2007 | 11:13 AM
cm3's Avatar
cm3
Tranny Question
Got a 82 n/a and having an issue with my tranny. one day i was comin from work and had been in ATL traffic for about 45 min i got on the offramp and was waiting for the light in neutral. when the light turned green i went to put the car in 1st and it wouldnt go. i finally had to force it in. that has been going on for about a week. most of the time i can push the clutch in firmly and it will go in to gear easier. does anybody have an idea about what this could be?
Old 02-13-2007 | 11:17 AM
Check your clutch fluid reservoir... prolly low on fluid. Also look under the drivers dash @ the clutch pedal. Look for leaking fluid on the firewall. Sometimes the clutch master cylinder seals go out & leak brake fluid, as well as the slave cyl.
Old 02-13-2007 | 04:31 PM
cm3's Avatar
cm3
yeah i thought the same thing so i added some fluid but the problem remains. but it had gotten bad where i had to really force it in 1st & 2nd but 3rd & 4th would grind when i tried to shift. but for some reason this morning on the way to work it was as smooth as silk. i just went to lunch a couple hours ago and it was pretty much smooth but i know that there has to be a problem so i'll check on the leaking fluid on firewall. Thanks
Old 02-13-2007 | 04:38 PM
skittle's Avatar
Taste My Rainbow
Maybe Your Sencros Are Going Out... Sound To Me Like Time For A Rebuild
Jack up the car & have someone pump the clutch pedal while you watch the slave cylinder on the tranny.... if it's not moving much, you know it's a hydraulic prob. If it is moving the correct distance, you may have syncro probs.
Old 02-13-2007 | 04:50 PM
skittle's Avatar
Taste My Rainbow
^^^ Thats How You Spell It
Old 02-13-2007 | 08:38 PM
RodMoyes's Avatar
Doesn't post much...
Actually, no... It's not how you spell it.
Synchro... is how you spell it.
Rod.
Old 02-13-2007 | 10:03 PM
skittle's Avatar
Taste My Rainbow
Ok Ok So I'm An Imbacile When It Comes To Speling. Watch Out Snow I'm Gain'n On Yas
Old 02-14-2007 | 04:02 AM
Fantagon's Avatar
Its a pretty common prob with these boxes ive found. 1st and reverse are the ones that go. Does it go easier if u throw it through a few gears, if so synchro's goin.
Old 02-14-2007 | 04:41 AM
BigBirdsZ's Avatar
maybe u got air in the system try bleeding the slave cylinder
Old 02-19-2007 | 03:40 PM
cm3's Avatar
cm3
Bad!
Well i took my car to a tranny shop. now of course the guy said that there r internal problems. he used some technical auto terms to say my synchros are bad. i thought the synchros would scape and grind at all times but when the car is off then i can move through the gears easily. does that have anything to do with the synchros?
Old 02-19-2007 | 03:56 PM
If the car won't go into gear when the engine is running & the clutch pedal is in, there's only two main probs:
-Something in the clutch hydraulic system / clutch itself has failed & isn't engaging the clutch disc to stop the gears from rotating.
-The synchros / gears have been ground enough that they won't grab each other when engaging.
Old 02-21-2007 | 04:38 AM
BJ BISIG's Avatar
Tranny
My S10 Was Doing The Same Thing. Thought The Clutch Was Going, All That Was Wrong Was A Broken Clip That Holds The Rod From The Slave Cylinder To The Clutch Fork.
Just My $.02, Bj
nka04a
13
04-07-2006 02:33 PM
thehrtbrkkid
08-17-2004 10:03 AM
theramz
01-21-2004 09:20 AM
CatchinZs
350Z Performance / Technical
12-24-2003 07:56 PM
WingsofWar
03-20-2002 11:27 AM
