Trannys that fit
Old 09-07-2003 | 06:40 PM
zpeedracer25's Avatar
Why not use the Borg Warner T5 that came in the 1982-83 280ZX turbo? Its strong enough to stand up to 300+ horse and is a fairly simple install into the NA chassis. You just need to find the transmission crossmember, driveshaft, differential flange, oh and the T5. I haven't heard of anyone trying to install a tranny from the Z31. You might check Hybridz.org for more input on alternate transmissions, but the easy proven transmission is the T5.
Best of luck!
Old 09-13-2003 | 09:22 AM
lifegrddude's Avatar
Externally Wastegated
If I remember correctly, the trannies aren't the same, but the shifters were. For a short shift kit, many use the Mustang one from B&M.
John 82ZXT
Old 09-14-2003 | 08:27 PM
well the body of the tranny is the same, but the input and output shafts are different and the gearing is different. And as John said the short throw shifters made for the Mustang trannys will work.
Old 09-20-2003 | 08:44 PM
Originally posted by RunninOnEmpty
does that mean an SBC will bolt up to the ZX tranny w/o an adapter?
if by SBC you mean small block chevy, then no. the bell housing is different...you would need one for the one for the chevy and you would need a different input shaft installed in the tranny unless the chevy has the same input shaft....but I doubt it. I do believe a tranny shop could swap out the input shaft...hmmmm.
Old 09-21-2003 | 07:14 PM
Runninonempty,
If the steering box is in the way, try finding an older ZX like a 1979 or 1980 base model. They had manual steering racks, you would need the engine cross member to go with it though. This would ease your pain for installing a turbo or V8.
Zuphoria
08-15-2015 11:51 AM
davidjoe007
08-17-2008 09:48 PM
Ramen Sama
04-12-2003 12:01 AM
GOZFAST
10-14-2002 07:50 PM
