Transmission swap?
Old 04-17-2009 | 12:17 PM
BlueKitsune's Avatar
Intrawebz Wizard
Transmission swap?
Ok Sounds like I might be getting a 82 Turbo Z! One downside is its auto so Im wondering with a n/a 5 speed trans from 83 work on a 82 turbo?
Old 04-17-2009 | 12:33 PM
Yep. All L-Series transmissions can interchange w/ all L-Series motors. When swapping from auto to manual, you have to remove the crank to flexplate adapter to install the flywheel & clutch. You also have to do something w/ the inhibitor switch so you can start the car. I think Fubar made a thread about the auto to manual swap.
EDIT... oh yeah, don't forget to swap the driveline & diff flange too.
Old 04-17-2009 | 01:14 PM
Intrawebz Wizard
Ok I'll look for the thread in the mean time, how do I add that extra pedal? I take it the mounting locations already there?
Oh and I really should have said, will that transmission hold up?
Old 04-17-2009 | 06:31 PM
you need the whole pedal assembly. i have a manual pedal assembly for an 82 i believe. errr... actually i mighta sold that already. now im not sure..... lol but its a brake and clutch pedal on the same assembly.
Old 04-17-2009 | 08:51 PM
Intrawebz Wizard
Remember that 83 I have? Well Its parts now for that turbo car lol Im parting it out entirely then Im just gonna cut it up I guess. at lest I dont have to goto a junk yard for all my parts!
Old 04-17-2009 | 10:39 PM
cool... or go all out and add an S30 to the equation and mix parts from the 2 S130's to make a nice turbo S30. that would be best
Old 04-18-2009 | 08:57 AM
Intrawebz Wizard
If I can find an S30
Old 04-18-2009 | 10:23 PM
duowing's Avatar
NisTuner
I have the clutch pedal/master cylinder assembly for a 280ZXT.
Old 04-18-2009 | 10:42 PM
Intrawebz Wizard
Is there any diff in a 82 n/a assembly?
Old 04-20-2009 | 12:09 AM
duowing's Avatar
NisTuner
Oh no, I don't even know why I put ZXT. Pedal assemblys are the same.
Old 04-20-2009 | 06:40 AM
Intrawebz Wizard
Ah ok no worries lol
Old 04-21-2009 | 03:02 PM
BigEkak1941's Avatar
The 82 & 83 parts should be interchangable. The clutch/brake assembly is one piece & will mount to the frame under the dash. You will have to change the speed O cable probably. Also change out the ECU (computer). I also think there will be some wiring differences, but don't quote me on that. There are several indivs on the forum who know more about that than me. If you are going to swap out the tranny you might as well get an lighter flywheel (since you have to replace it anyways), as they sell on Ebay & several parts store the Alumimun (poor spelling), and get a racing clutch since I think you want a faster car? If you do your homework and not rush into the project you will be able to acquire all the parts & knowledge before starting the project. That will save you both time and money. Good luck and don't be afraid to as questions as that's how you learn. Dan
Old 04-24-2009 | 09:58 PM
Intrawebz Wizard
Ok thanks! Tho it doesnt matter sense I got the car for the swap but now I know what to do
BlueKitsune
06-20-2012 09:14 PM
JBs280Z
07-19-2007 06:38 PM
FranksZ31's
07-19-2006 03:14 AM
fokker300ZX
10-24-2004 11:40 PM
762x54r
03-25-2002 01:47 PM
Quick Reply: Transmission swap?
