Trying to install CD player.
I want to install a CD player in my Z. All I've really been trying to find is how do I get the original stereo out of there and put in my CD player. Do I have to pull a whole bunch of stuff out to get the stereo outta there, or what? This is the only thing I can't seem to figure out.
The stereo 'console' comes out as one piece.
Remove the trim panels under the dash to access the upper screws (2 per side) and remove the small trim plates at the bottom of the stereo console to remove the lower screws (2 per side).
Now the whole stereo console will slide forward far enough for you to disconnect the radio wiring harness that uses two plastic molex connectors (depending on which stereo option you have), a power connector and the antenna connector.
Now you can remove the entire stereo console to remove the old components and install the new components. You'll have to splice in the new wires into the old harness or you can scavange the molex connectors from the old radio and make a nice clean 'quick' disconnect.
Good luck!
Good luck!
And for installing your new CD player you can pick up an adapter plate from MSA so you can fit a din sized headunit. I don't know how much they go for but they got em. Otherwise you'll have to find some way to rig it up. If you're handy with a grinder you can make your own panel too.
My god I can't make heads or tails of this wiring. I need to get a guide I guess. I've been trying to pull the panels off to get to the back speakers, they're on there very tight and I don't want to break the covers. As for the wiring, I've got all different kinds of connectors everywhere, and I have no idea which even run to the speakers. Does anyone have any good wiring diagrams? It's going to be about a week until I can get my guide anyway.
You are way better off running all new wire than trying to use the original wiring. For one, the original speaker wiring uses common grounds and the wire itself was not really made to handle the wattage put out by modern head units. It's a little more work, but it will pay off. As for the mounting plate, I made mine from aluminum... it was pretty easy.
Rod.
Rod.
Do all models of the 280zx use common ground wiring? I know on the 300zx the GLL had an amp, and didn't use common ground wiring which made hooking up an aftermarket cd player much easier.
As far as I know, all of the 280Zx's used a common ground set up. Now, the later model 300ZX's and Maxima's that had the factory installed "BOSE" system... Those were a MFPITA to change the system on. You had no choice but to re-wire them because the Bose set up had inline amps for each speaker. Most stereo shops won't even touch one.
Rod.
Rod.
That'd be very helpful. Thanks in Advance Nismo. I'm gonna see if autozone has the Haynes guide in, I need to pick one up regardless. Right now I at least want to get my cd player hooked up so I can get some music, even if it's not the best sounding. Then eventually rewire the speakers. How hard is that to run new line to say the back speakers? Do you have to lift up the carpet and run the wire under there?
Do you think if I went to a electronics store like Best Buy that they can replace my stereo? I have 83 280 Turbo and the one I have now works but the HUD doesnt display anything. I wanna change it but am wondering if they can do it or if I would have to do it myself. What do you guys think?
Yea, NismoPick is right, you'd be much better off to do it yourself. I wouldn't trust Best Buy for one, they couldn't give me the right parts to mount a CD Player into my 300ZX when it was running. Plus I would rather do the wiring myself so I know what I did, rather than having a bunch of Best Buy goofs screwing around in my Z. Maybe my van or something, but my Z is different.
Best Buy wouldn't do the install anyway... neither will Good Guys or Circuit City. Z car's have been effectively black-balled as far as stereo installation goes from all of the major national chains. You're way better off doing it yourself anyways. I agree about knowing what you did rather than guessing what some 7 dollar an hour hack managed to splice together in a hurry just to get your car the hell out of there.
Rod.
Rod.
Be careful even when you go to a reputable car installation place such as Audio Express, they did an install on my friend's BMW, and taped off a few wires that weren't being used. These were just dangling down from the rear speaker area, and looked like total crap.
Thanks for the input. I wanna get a stereo this weekend for the car. I guess now im probaly gonna install it myself unless the best buy guys will do it. Someone was supposed to put the wiring schematics on tonight so if they are available than ill definatly do it myself.
Take that stupid "pro-installers" !
Rod.
