Turbo Z problems!
Guest
Posts: n/a
Turbo Z problems!
ok, i have an 83' turbo 280zx...high rpm, under full throttle, i have NO power. I have full boost, it doesn't sputter or jolt...well, low rpm, full throttle, it sputters...but high rpm, full throttle, full boost, NO power...i hate this. I've also noticed a slight backfire when i coast down from mid to high rpm...if anyone could give me any advice on this, it would be awesome
Guest
Posts: n/a
How are your plugs? How old are they and how old is the diz-cap? Coil? Could either be bad timing, weak ignition, or poor AF ratio - which could just be tuning, injectors or fuel pump.
If the cat is dead, let the car idle for a couple minutes and look under the car, if its glowing red it is finished/clogged. Bang out the materials if you dont care about smog, or buy a new one. It can also do this though via fuel or timing problems making the exaust very hot.
