V8 conversion
Old 03-02-2013 | 02:09 AM
ChucksZ's Avatar
V8 conversion
I just got my 1981 280ZX,I will be installing a 1995 LT1 with 4L60E transmission, I will need some technical assistance as I go along has anyone done this conversion before?
Old 03-03-2013 | 06:51 PM
Lazlo's Avatar
Try Hybridz.
S130 Series - 280ZX - HybridZ
Typically better info there for the type of build you are planning. The site's search function can be a problem, so try googling it and then selecting results from HybridZ.
Old 03-04-2013 | 11:35 PM
You may need to swap to the recirculating ball type steering as it moves the steering shaft to the side instead of thru the path of the exhaust header. Mounts aren't too bad. Jtr made the kit and headers I used but it was a traditional 350 chev build. Everything else I felt was pretty straight forward. I used the Chevy power steering pump with the Datsun threads welded to the output with a tig unit
El Zorro
04-29-2015 12:01 PM
Nforce1
08-04-2005 10:38 PM
nightlights
04-07-2003 11:45 PM
FLiPSyDe71
12-12-2002 12:33 AM
DemonZ
10-20-2002 02:08 PM
