vacuum line connections - what goes where
i'm unsure where the vacuum lines go, mainly concerned from the a/c vacuum tank. it has 3 vacuum ports, 2 of them are going into the intake manifold (i have the non egr manifold) and the top one is not connected to anything. where does this one plug into and do i have the other 2 connected correctly?
thanks
thanks
Yeah... you have those hooked up wrong.
3 lines on the vacuum tank:
-one goes to the vent selector in the cabin.
-one goes to the check port on intake.
-middle one goes straight to the intake.
The way you have the vent vacuum line from the intake, when you jam the throttle, all the vents will default to floor & defrost because there's no vacuum.
Scan from the Haynes / FSM:
the_journeyman
09-22-2011 08:04 AM
davidjoe007
07-29-2005 03:22 PM
