Warning dash light thing Qs
I just noticed today that the check thing in the dash doesn't light up all the symbols it used to anymore, mainly when theres something wrong it doesn't glow red at all. Is there bulbs inside of the thing or is it just broken?
It's basically a vacuum tube or a nixie tube with a bunch of different filaments that are selectively light up by the controller. IIRC the controller is mounted on the rail directly below the glove box so you'll need to pull the kick panel below the glove box or the glove box itself to get at it.
More details - do any of the filaments light up? You should be able to stimulate a fault by activating the signal to the control unit. Which ones aren't working?
Just the Warning one itself now that I went to watch it a few times, triggering different ones.
Say this. you start your Z and all of them flash through then it gives you the OK then you touch your brakes and a bulbs burned out instead of glowing red to show something is wrong, it does nothing. If you hit the button it will say the light is out, but will never glow red.
At least yours works mostly. Since I have had my slicktop, I can't get my check light to work at all. lol It would be nice for it to work. It was handy, when I had my T-top running.
FricFrac....Thanks for the tip, I was wondering where I could check for it. Maybe I can figure it out, and get the check light going. Who knows.
Ah well its nothing big just being a little nit picky so I can have it working right lol I wonder if I can update mine so it doesn't have the battery check thing anymore. I have like 5 different wires coming off the + side of the battery and one less would be nice lol
I wonder if I still have a spare gauge cluster left... maybe I'll swap out the light thing
Just trying to figure out where the problem is coming from. I was digging through the wiring harness stuff when I did my car alarm/imobilizer and to disable the headlight detector for HID's so we can probably figure out what's going on here with a few more details...
No no no. those lights work just fine, But you know how when a fault is induced after its done its first OK check when you start your Z, the window glows red to show something is wrong to make you push the the button so it can tell you. That light on mine doesn't work anymore.
If you cause a fault does the red light come on when you first start the vehicle rather than when you press the check button? If for instance the washer fluid is empty and you press the button does it detect that the wiper is low and flashes the wiper icon but no red light? I'm assuming you just never get the red light?
I used to get the red light when something was wrong. But now I don't, even if I introduce multiple faults in the system, Washer, coolant, headlights, tails lights, ect.
I just never get a red warning light anymore. I used to tho
Don't forget you may have a bad connection between the control amplifier and the display. There are a few plugs along the way. I'd ring it out myself...
I MEAN it flashes all the lights though when you start the car and it you push the buton it does its check and says OK. BUT if theres a fault AFTER the FIRST check when you start your Z it WILL NOT glow red to show there is a new issue BUT if you hit the button it will go though the checks and flash at you what is wrong.
Basically it wont glow to show something is wrong if something is wrong. but if you push the button it shows what is wrong.
EDIT: Wait why am I still going on with this. I got my question answered. The box is fine its giving the right power outs to the right bulbs or w/e is in that warning display and theres no bulbs to replace. So the warning display in the dash must be damaged or something.
Thanks man, so it is above the kick panel more upwards? Kind of hidden out of the way, where a lot of plugs and connectors are? Do you know how many plugs are in the box? I didn't know much about it before.
If you have a second control amplifier I would simply swap them and see if it works. Baring that I would first check to see if the output from the control amplifier is outputting to the signal for the "RED" on the nixie tube. If it's not the control amplifier needs to be replaced. Then I would pull the gauge cluster and see if the output is getting to the nixie display. If it is then you need to replace the display itself.
See - simple! ;P
