What the!?
What the!?
Ok this is wierd. After a very hard drive today my fuel , brake, and door lights keep popping on and off. Also my voltometer is running a little low. It's staying a little under 14 volts or right at it when it normally runs at about 16 volts. I have no idea what is going on with it. What do you guys think is happening here because I am completely baffled. Look foward to hearing from you guys.
Pete
Pete
I had the same problem it started out like that. What happend in my case is that i opened the hood one night that was happening and the positive side wire to the alternator was glowing bright red. Meaning I had a short well i changed out my alternator and changed the wire hook ups cause they got melted after that never had a prob with the lights like that turning on again.
