What did you use for an Air Duct?
Old 08-04-2006 | 12:07 PM
  #26
jfairladyz's Avatar
it is counterclockwise from #1. And you go in the firing order, not numerical order. Dont go 1, 2, 3, 4, 5, 6. Its 1, 5, 3, 6, 2, 4.
The only reason I mentioned fuel is because the car has started and run on starting fluid. Thats what led me to believe the engine is just not getting any/enough fuel.
Old 08-04-2006 | 12:54 PM
  #27
...the car has started and run on starting fluid. Thats what led me to believe the engine is just not getting any/enough fuel.
that's what I was wondering! Ya, either not enough or way too much fuel. Clean those plugs off if its too much.
counterclockwise is the way. 4 and 6 cyl L-series are all counterclockwise. J has the firing order correct. Listen to that man. He has the Authority!
Old 08-05-2006 | 09:30 PM
  #28
FubarI33t's Avatar
Damn. i got them clock wise. I have them clock wise on a 80 Z. and she runs strong. i'll get a chance to try it all out in the mornin. Been busy painting a f150 all this weekend.
Old 08-06-2006 | 04:07 PM
  #29
FubarI33t's Avatar
Wires are right. Timing is good. Injector's are NOT fireing at all. none of them. not even a drible. What should i look for into geting these to fire?
Old 08-06-2006 | 06:03 PM
  #30
FubarI33t's Avatar
I swaped in another ECU. still no injector fire. Both ECU's trobleshooting lights on bottom flash once real quick during key start
Old 08-06-2006 | 08:53 PM
  #31
jfairladyz's Avatar
start tracing the wires with an ohmmeter and a voltmeter. A wiring diagram is going to come in handy here. Make sure the ECU is getting a signal from the dizzy. make sure all the grounds are grounded from the ECU. Trace all the injector wires.
most likely the ECU is either not getting it's signal to tell it to fire the injectors or you have a bad/disconnected ground. If the 82's had dropping resistors then you'll want to check that out too.
Old 08-07-2006 | 06:56 AM
  #32
FubarI33t's Avatar
can a bad ign module stop the injectors from fireing?
Old 08-07-2006 | 12:54 PM
  #33
FubarI33t's Avatar
Ok. i have been folowing wires all day. I don't know how to use my volt meter, but it does have a ohm thing on it. If some one will tell me how to use one. i might be able to check wires easyer
dag88
09-08-2011 07:50 PM
HexaggramJDM
07-12-2011 01:29 AM
thxone
05-19-2006 02:43 PM
G35_S_&_C
07-13-2003 01:54 AM
Quick Reply: What did you use for an Air Duct?
