Wheel bearing bad?
Wheel bearing bad?
I got a 82 280ZX. I was checking out the brakes and I noticed that I can move the wheel in and out a little (which from past experience on other cars is usually the wheel bearing). I was wondering how I would know if it's the inner or outer bearing? Is there some way to try to adjust them or are they just bad? It drives nice, but never drove a perfect 280ZX.
Yeah, I saw the FSM. When I look at them, would there be a discolored spot or warped looking? If I do replace them, do I need to replace the races, and both inner and outer bearings? Thanks.
Maybe also, you could have a bad ball joint. That is what happened with my '82 slicktop. Somebody must have hit something real hard on that one side. (Which is the driver's side) And destroyed the ball joint. I did end up replacing both new. Anyway, good luck man.
jbell551
06-02-2005 08:13 AM
