White smoke.
White smoke.
Ok guys here it go i have smoke coming out the tail pipe , also alittle sputter the radiator has a little oil in it i was thinking head gasket what do you guys think replace the head gasket or replace the engine.
do a compression check and dont drive the car! if you (which you probably did) blew the head gasket you dont want to burn coolant it can cause some head aches. you'll probably have to get a new headgasket and it might be smart to get the head milled and new valve seals and a valve job done. maybe even the timing chain setup, or at least the tensioner, but not necessary. happy spending! (its less than a 300 dollar job with headwork i suggested so no big)
