Z won't Start.
Z won't Start.
My 83' 280zx has trouble starting every morning. I dunno if the battery's being drained everynight or what, but I MAKE SURE to turn everything off inside the car. Doors are shut, lights off, everything. However, It still won't start. It's making me late to school everyday.... (which I don't mind, but my folks do) HELP?
-KD1
-KD1
ummmm.... details? wont start cause the battery is dead every morning? so you jump it? or what. thats WAY to vague of a description of what you have to do to make it start and its characteristics for us to say anything
Its possable cold start valve i had a 1983 Na and i had to buy a new cold start valve and it fixed the problem.. then later on i figured out how to fix the old cold start valve ! i unpluged it from the harness then i had to take off the antifreezze lines then i was able to un hook both hoses from the front and rear ... then i took off the cold start valve and opened it up... low and behold there is a spring in there and there was alot of " suit " build up dust ... so i used some carb spray and i used a little bit of oil...10-30 weight to relube the spring then i put it back togethor but yet still didint work well so i used my " haynes " manual and saw u can adujust !!!!! the little bolt on the cold start valve to open faster on really cold days ! wow bingo ! problem fixed ! so i took my new cold start vlave back to autozone and got my money back !
if u have a meter check voltage when you are running make sure it is like 13vdc or better, turn off car and it should be 12.something, then in the morning see if the volts lowered. if it did then u have a short somewhere draining the battery over night. if it stays at 12 volts you have a starting problem. if it is not reading over 12 volts while running. disconnect the battery while it is running. if the car dies the the Alt is bad and not charging the battery enough so the car is running off the battery, then you will need a new alt and maybe battery since it has been the source of power while running and cells could be going on it..
my 2 cents
my 2 cents
Just waiting on details.....
I presume the batt is dead in the morning. Is it dead right after running?
Have you taken it to a place like Checkers for a free charging system check?
Could you please be less vague, and we will get you all fixed.
exactly. It will say its charged when I leave it at night but by morning it will be dead. It hadn't done this in the whole year that I've owned it so I dunno whats going on.
if it is dying over night. then it is possible u have a short to ground somewhere, i have a friend that also had the wires going to the alt crossed on time so it was supplying a ground and causing it to drain, disconnect the positive and make sure it touches nothing. then shoot from every place that battery power is at. like the battery power at the radio...with battery disconnected put one lead to the wire and the other to a good ground. if you get continuity at any of those places u have a short and can then figure it out.
theres only three possible problems, dead alternator dying battery or a parasitic drain. start with the first two since they are easily tested for free at autozone.
To perform a proper load test, they have to make sure the battery is fully charged, and disconnected from everything but the large load testing machine. Hand Held testers do very little to test a batteries reserve capacity.
In AZ you are lucky to have a batter that stays in good health even for a year. I go through them often. Especially the abuse I give them.
I need to figure out what's doing this in my 300zx. Whatever it is doesn't kill it over night, but like my battery will generally not have enough of a charge if I don't drive the car for like a couple of days.
