Are Z's top speed limited by weight?
Old 01-13-2009, 01:42 PM
  #26
Haterade by da gallon!
280zx2by2's Avatar
Originally Posted by SHADY280
i know my wing and airdam helped tons on my car. you can actually feel it sink to the ground as speed increases. ive had my stock z to 180kph, but never went faster due to traffic, now that its modded, ive had it a little past 220kph. my brother had a very worn out lowered s130, he took it to 185kph, but man that thing felt scary at 100kph!!
what is kph? kicks per hour?
i know my wing and airdam helped tons on my car. you can actually feel it sink to the ground as speed increases. ive had my stock z to 112mph, but never went faster due to traffic, now that its modded, ive had it a little past 137mph. my brother had a very worn out lowered s130, he took it to 115mph, but man that thing felt scary at 62mph!!
scary at 62 mph!!!! it must have been WORN OUT
280zx2by2 is offline
Old 01-13-2009, 02:45 PM
  #27
hehehe thanks for converting the speed over!! ahahah. yeah every bushing was shot, the ball joints and tie rod ends were badly worn, plus it was lowered and only the inner edge of a 195/60/r14 was touching. due to that it also could lay rubber thru 4th gear with only a p79 head shave and headers done to it. i ended buying the car and taking it all apart then throwing out the rusted hulk of a body.
SHADY280 is offline
Old 01-13-2009, 05:48 PM
  #28
KingDatsun1's Avatar
yes, I was wondering what the best gearing would be if you wanted a high top speed Z. My Z is running 55mph at like 3k rpm in 5th. lol I think thats really high
KingDatsun1 is offline
Old 01-13-2009, 06:22 PM
  #29
280zx2by2's Avatar
not for an import from the 80's lol...
Old 01-13-2009, 08:03 PM
  #30
Stupid Hurricanes...
260zturbo's Avatar
while back they had a calculator you could plug in your transmission gearing, rear end and tire widths. would give you the peak of your gears. I believe it was on zhome but he changed his site.
260zturbo is offline
Old 01-13-2009, 08:09 PM
  #31
the calculator said with my engine, tranny, diff, and tire ratio, my top speed would be 180mph!!! it also was calculated for the areo of a zcar, not just any car. so it could be accurate.
SHADY280 is offline
Old 01-13-2009, 11:28 PM
  #32
Externally Wastegated
lifegrddude's Avatar
The tallest ratio would be to get a 3.36 rear end with a late zx 5 speed. That will give you the theoretically highest potential top speed, although you'll need a bunch of power to get there.
If you want to mess around and see what different things will do for your top speed, (aerodynamics not calculated) go here:
http://www.geocities.com/z_design_studio/
It's also a good way to see how far off your speedometer is too.
lifegrddude is offline
Old 01-14-2009, 12:35 AM
  #33
NisTuner
duowing's Avatar
my speedo is actually really pretty much right on in comparison to the transmission calculator. Also it's really pretty accurate in comparison to those speed signs.
duowing is offline
Old 01-14-2009, 07:17 AM
  #34
apparently if im booking it along the freeway at 200+ kph, even the police helicopters cant keep up. my buddy is a pilot, he was amazed i could go that fast, but saying that, hes never topped 110kph in a car. yeah ive tested my car against the radar signs, seems to be bang on accurate.
SHADY280 is offline
Old 01-14-2009, 05:47 PM
  #35
280zx2by2's Avatar
apparently if im booking it along the freeway at 120 mph, even the police helicopters cant keep up. my buddy is a pilot, he was amazed i could go that fast, but saying that, hes never topped 70mph in a car. yeah ive tested my car against the radar signs, seems to be bang on accurate.
am i missing something or are cars slower in canada... i drive at around 80-85 on the introstates (any faster and i couldnt tell the cop how fast i was going) and people fly past me...
your whole "colder air" idea must be a load of guanno!!! lol i guess its dif. in canada... the mounties must have awesome speed guns
Old 01-15-2009, 12:58 AM
  #36
eff good grammar
Niku-Sama's Avatar
downforce isnt much of a help at 110-120 mph but like you said frontal surface area and the flow of air around it would be the bigest hinderance of speed... downforce just keeps you from turning that speed into a highspeed wreck (picture the F1 cars flipping 30 feet in the air)...
and you do realize that planes have these things called wings that have 10X the surface area of a car... i thing your seriously under estimating the force of GRAVITY.... lol
my z dosent weight 1700 lbs, and you still fail...
i belive my brian just melted!
well i think it depends on alot on how the car is equipped like my car 80Mph is about 4k rpm. it will accelerate right up till it runs out of gear or the engine spins apart from the bijillion RPM its producing.
sounds like your a little better off than i am.
this can work the other way, depending on the gearing if they are too tall of gears and the car isnt powered very well there will be resistance in trying to move the drive train on top of moving the car across the ground and through the air but you would need really tall gears and a lawn mower engine unless your final gear is unusually long.
Niku-Sama is offline
Old 01-15-2009, 03:17 PM
  #37
lww
Head Muckraker
lww's Avatar
Try this site: http://www.geocities.com/z_design_studio/
lww is offline
Old 01-18-2009, 02:39 PM
  #38
hughdogz's Avatar
From what I've read, S30's seem to "top out" around 125-135 MPH without any aero. I gather that the S130's can (more comfortably) maintain that speed due to the better Cd. "stock for stock"
(ducks head...)
hughdogz is offline
PowerhungryBill
01-16-2006 06:48 PM
r2bgirls
08-16-2005 08:35 AM
81 Black L28E
06-17-2005 07:39 PM
Tuuurbo
11-03-2003 07:07 AM
FPguy
05-27-2003 02:56 PM
Quick Reply: Are Z's top speed limited by weight?
