1984-300zx
Old 04-05-2005 | 05:36 PM
jodies300zx's Avatar
1984-300zx
My alarm has mal-functioned and is going off constantly preventing me from starting it. Is there any way to dis-arm the alarm until I can get it replaced and if so how? jreynolds5138@charter.net
Old 04-05-2005 | 06:42 PM
entropy31's Avatar
The Cake Is A Lie!
stock or aftermarket?
Old 04-06-2005 | 08:10 AM
The alarm is stock
Old 04-06-2005 | 10:49 AM
Redbeauty84ZX's Avatar
Pulling the fuse should do the trick. I believe its the Theft Warning fuse.
Old 04-06-2005 | 12:41 PM
entropy31's Avatar
The Cake Is A Lie!
yep jut yank the fuse and you should be ok, then, if you really want an alarm just get an aftermarket. the stock one really isnt worth fixing.
Old 04-07-2005 | 07:49 AM
My hubby took the one out of the fuse box inside the car and it didn't stop it. Where would the "Theft Warning Fuse" be? The horn is still blowing and if he takes the relay out the car won't start.
Old 04-07-2005 | 06:50 PM
On the panel over the fusebox it says inside which fuse is which.
Old 04-08-2005 | 05:49 AM
entropy31's Avatar
The Cake Is A Lie!
its possesed. find a priest
where did you look for the fuse, it should be a fuse, not a relay
Old 04-24-2005 | 06:11 PM
micber309's Avatar
You should be able to disable/turnoff the alarm with the door key either in the driver's door or by opening the hatch using the key.
I just fixed my alarm by raising the hood pin switch. I just put a couple of flat washers underneath the bracket that holds the switch.
You will know if it is working properly if when hood, trunk, and both doors are closed and locked the security light on the dash will not flash. It will stay on for about 45 seconds and then go off and then your alarm will be armed. If it is still flashing that means that there is a switch malfunctioning and the alarm thinks something is still unlocked.
Old 04-25-2005 | 10:53 AM
entropy31's Avatar
The Cake Is A Lie!
my hood pin broke off its bracket (cheap #^%$ plastic) so i have the blinky security light all the time. it doesnt really bother me because a blinky light is a deterrent by itself if the thief doesnt know about the car. if i ever decide to put in an aftermarket alarm, i think i would try to locate its blinky light in the place of the bulb for the stock security light. i hate putting unnessecary holes in a car.
Jaytee Phan
FS: 300ZX (84-89)
03-28-2012 11:40 PM
kittyz
10-03-2009 02:59 PM
nismo619
10-27-2006 10:11 PM
PeterPaps
06-30-2004 12:32 PM
zstopnshop
08-25-2003 04:57 AM
Quick Reply: 1984-300zx
