aftermarket power antenna install
Old 02-12-2007 | 07:13 AM
Turbo86's Avatar
anybody install an aftermarket power antenna ... I need to pick your brain
Old 02-12-2007 | 07:49 AM
so.... yeah.... whas the problem?
Old 02-12-2007 | 09:58 AM
Turbo86's Avatar
theres 3 wires (1) green/blue (2) green/white stripe (3) yellow ... the service manual shows 1 positive and 2 negative makes it go up ... then it shows 2 positive and 1 negative makes it go down and the yellow wire ? ... I have a red wire thats supposed to be the hot all the time wire and a green wire thats hot when I turn on the radio and a black wire that I'm supposed to ground with a screw ... my logic was the down position was the one that's the off state so do I splice the red wire to the the (2) + wire and the green wire to the (1) - wire and when the radio turns on they switch to 1 + and 2 - and the yellow wire is not used? ... I thought yellow wires were hot wires?
Old 02-12-2007 | 12:49 PM
AZ-ZBum's Avatar
get a volt meter and test the wires.
turn the car off and check each wire for 12V. = hot wire.
then, turn the car and stereo on and check for 12V. = signal wire.
carfanatic
11-11-2009 10:34 PM
maxxypearl
09-30-2009 09:31 PM
duowing
09-16-2007 03:58 PM
colin_barnes
09-29-2005 05:52 PM
1SIKZ
04-08-2005 06:14 AM
