Power Window Switch
Power Window Switch
New here, but not new to my Z. Before I tear into the door panel, does anyone know if the window switch (drivers side) can be cleaned? The switch works fine for the drivers window, but the passenger side doesn't work that well (sometimes not at all) but the passenger switch works just fine. I'm thinking that the contacts are a little dirty.
Thanks.
Thanks.
Cleaning the contacts is probably about as permanent as replacing, if you do it well. It's rather tricky, though. I just replaced my driver side switches with a used set, instead of trying to clean them this time. I did clean the used one before I installed it, though.
stiletto660
03-13-2009 02:11 PM
Comorat2x2
01-18-2006 10:45 PM
