t-top seals
First you've got to knock over Fort Knox, then go shopping.
This vendor (very reputable) sells what you need. MotorSportAuto is the vendor of choice (mine) for Z specific parts.
I've linked you to the item that is most likey leaking on your Z. You can jump to some other similar items from this page, or, shop their entire on-line catalog.
Link to weather stripping page
Guest
Posts: n/a
www.victoriabritish.com also has them. I don't have the catalog in front of me to give you a price, but they will send you one for free.
In my VB Spring '04 catalog, the body seal is $130/ea. side ($260 for the set), and $60/ea. side ($120 for the set) for the top T-top/door seal. None of my seals are that bad, but I have had a few leaks. Silicone had worked for well for me, and it's not that noticeable if applied properly - assuming they are small, and not major leaks.
