Diff mount modification?
Well, this may be a silly question. But I just gotta ask.
Has any one tried filling the rear differential mount with polyeurothane to make it stiffer/last longer?
I've done this with other vehicle's motor and transmission mounts with fairly good results. Just wondering if anyone here has tried it.
Originally Posted by my86z
Now, that I might be able to pull off. What thickness would be recommended for the material? 1/4", 1/2", 1/8"?
I'd go at least 1/4 inch.... thicker isn't any more difficult to fab, and it's going to be stronger. You will need that especially if you will be doing any auto-x or racing. Look at the stock mount... it's not flimzy... so don't make a custom one weak.
You should also be aware that sold diff mounts make hella-noise.... you hear road and mechanical noise a lot more.
Couldn't resist pimping a pic of my home made diff mount. Not bad for about $8 and some time with a tape measure and drill press. 1/2" angle Iron is MORE than enough for ANYTHING I can imagine ever throwing at the car.
Pic is of a test fit which is why there's missing nuts and nothings tightened down.
