4 LUG 5 LUG
Old 01-10-2002 | 04:41 PM
Spot's Avatar
Re: 4 LUG 5 LUG
you can swap the front to 5-lug easy enough. any 84/5 turbo or 86na one would fit quite easily. 87+ would be good too, then you'd have floating rotors, much easier to change in the future. You *might* also have to swap the rotors/calipers (i think) on the 87+ type.
rears are a bit more difficult. you have to swap (at bare minimum) the stub axle, which is held on with a 30mm nut, underneath the halfshaft hub where it bolts to the backside of the control arm. it's most likely easier to just swap the whole rear control arm since that 30mm bolt is on with about 284 or so ft-lbs of torqe. an 86na is the only one with 5-lugs that will work properly in your car though. 84/5/6 turbo use a different bolt pattern where the halfshaft bolts to the stub axle, and 87+ all use a different size control arm which means different length halfshafts.
5-lug wheels are on 4.5" centers, the same size as on ford mustangs, although i think you need spacers (not sure what thickness) as the offset is different.
Old 01-15-2002 | 07:47 PM
Spot's Avatar
Re: 4 LUG 5 LUG
my bad. the 87+ 'TURBO' cars have floating ones. NA's have the bolted kind.
sorry about that.
