86 300ZX
Guest
Posts: n/a
86 300ZX
Just bought a 86 300ZX, the body is in great shape, but the interior needs alot of work. Where can I find kits, or parts to redo the interior,ie. carpets through out, center console (cover is missing), door and dash have some cracks in them. Please let me know..... Dpryan1@yahoo.com
Re: 86 300ZX
Check your local junkyards. if yours is a 2-seater then any otehr 2-seater's parts will fit yours fine. The only exception is the door panels. You will have to use 86 or newer door panels as the inside handle is in a different position. You can use 84/5 ones if you also get the rods connecting the handle to the inner door mechanisims - your '86 door will have the slot for relocating the handle cut in it already, but the connecting rods are different. If your car is a 2-seater, the dash and lower trim panels, and armrests (on the door) are the only thing from a 2+2 that will interchange with yours, everything else is sized differently. It's vice versa if yours is a 2+2.
nismo619
06-11-2012 08:56 PM
