86 300zx T won't start, Please Help
Guest
Posts: n/a
I bought this car like 2 weekends ago, and when I got home,it basically started to act up,would start alittle,but not all the time,now it will not start at all. It was flooding,so I put a new fuel pressure regulator on it, but now it seems to be getting no gas to the motor,but it does get lots of gas to the fuel hose. Could someone please help me out or tell me what you think could be wrong with it,thanks.
Re: 86 300zx T won't start, Please Help
try unplugging the air flow meter and see if it starts any easier then. if so, then the air flow meter is the problem. with it unplugged, the car will run but will not rev over about 2k rpm's.
Guest
Posts: n/a
to simplify it all, your car needs 3 things to start. air, spark and fuel.
Unless you've got your intake blocked off, you've got air. Now remove the coil wire from the distributor and set it on the upper intake plenum and crank the car. If it arcs to the plenum, then you've got spark from the coil. Now whether the spark is getting to the plugs and/or coming at the right time in relation to fuel spray is something else. (How old are your plugs and wires???). Before diving into that though, make sure you've got fuel. If you have a dying fuel pump, then it may start, but probably won't stay running, or it may run like it's starving for fuel. Attach a fuel pressure gauge after your fuel filter and see what sort of pressure you have. If you have no or little pressure there, then place it before the filter and see if that makes a difference. If it does, then your filter may be clogged. Back to the spark issue though, make sure your timing is set right. Rotate the engine til the #1 piston is at TDC, and the tiiiing marks on the lower crank pulley should line up with the timing indicator (should be 3rd line from the right as you face it i think - should be a sticker under your hood telling your where it should be.) the rotor should be pointing to the contact for the #1 spark plug on the inside of the distributor. If that's all good, then perhaps try removing the upper timing belt cover and see if the dimples on the cam's line up with the dots on the timing cover backplate. There should be 40 teeth on the belt between the dimples on each cam sprocket. If your belt jumped, that may also cause difficult or no start.
Sometimes a bad air regulator will make a car difficult to start, but often will eventually start. Ohms between the terminals on it should read 75. A bad CHTS may also make it hard to start (i don't remember the check for that offhand).
Have a look at those things, then post the results.
good luck
good luck
Guest
Posts: n/a
Still not running,but alittle imformation to update you on,and maybe you have some more ideas. I did the ECCU diagnostic,even though I have unhooked battery since last started car,but the codes that showed up were 13,23, 24,and 31. Also we had spark to the coil, and we had put new sark plugs and fuel filter on after we got the car. My dad told me to ask if the cylinder head temperature sensor could cause our problems,and also told me to tell you that the heater was blowing cold air before it stopped running. Hope to hear back from you soon,thanks.
You might have found the problem there in Code 24, it's the code for the neutral/park switch which I believe would prevent the car from starting. 13 is the cyl head temp sensor. If it's bad it can cause slight problems with the way the car runs but I don't think it will keep it from starting. My car will run with it unplugged. 31 is the a/c load, so you can disregard that. Turning on the a/c during the test would remove that code. 23 is the throttle position sensor aka throttle valve switch. It may need to be adjusted or replaced but the code would also come up if you didn't press the gas pedal during the test. Anyways, I think the 24 code is the real problem here.
ZenArcher
ZenArcher
Guest
Posts: n/a
Try starting it using starting fluid sprayed into the intake box.
If it kicks over on starting fluid its proabably a fuel problem.
If the car is turning over I doubt it is your ignition switch. If you have spark and fuel to the cylinder it should start unless you have some kind of timing issue.
Guest
Posts: n/a
Good news for once, I think we finally might have it. We put on new spark plugs once again since we thought it had flooded alot since we last put the new ones on, and now it has started 3 times in a row.wooooohooooooo. Thanks for everyone that has been here to help me out.
1985nissan300zx
09-22-2011 10:26 PM
