Alarm system
Old 10-06-2003 | 03:32 PM
CrAzY_84na's Avatar
VIVA LA Z31!
i dont kno the answer to your question but make sure you post over at Z31.com there a lot more people that read that forum for some reason
rob
Old 10-19-2003 | 10:31 PM
Spot's Avatar
it could be that the switch for the alarm in your drivers door is malfunctioning. It is a magnet switch attached to the lock mechanism with a bracket of plastic. It could be that the plastic has broken and therefore doesn't pivot to operate the theft switch when the key is turned.
Does the theft system engage when the drivers door is locked with the key?
Old 10-21-2003 | 10:45 AM
86ZXTurbo's Avatar
might be able to. I know some car companies keep records of the original keys for something like this. Ford does. theres little numbers on the original keys you are supposed to write down (on mine there are) or maybe they can help you with your VIN. good luck. if not you can just have all your locks redone.
Black260z
11-06-2007 04:37 PM
WichitaZRide
07-02-2005 07:55 PM
Cw2435
07-02-2005 05:37 AM
typeaproduction
06-27-2004 11:07 PM
Blue83zx
06-16-2004 09:06 PM
