aux lights
Guest
Posts: n/a
aux lights
I have an 87turbo and iam having trouble with my fog lights.
ok let me tell you whats going on they use to work fine until one day the went out i replaced the bulbs and the still blow the fuse i got under the car to see if something had come lose but i dont think it has i even tried a bigger fuse it still blows and i noticed that when i cut my high beams on only one works.
can anybody help ??????
Guest
Posts: n/a
Re: aux lights
I had almost the same problem. I fixed the fuse popping garbage by using shrink wrap on all of the electrical fittings in the light housing. Now there is no way it can short out it (blow the fuse). And as far as I know the fog lights are supposed to turn off when the hi-beams are on. Hope this helped.
jaySwiggA
jaySwiggA
Guest
Posts: n/a
Re: aux lights
While we're on the subject of fog lights, can these things be aimed. When I turn mine on, they seem to light up very high on the sides of the vehicle instead of low and in front, which is how I thought they should work. I haven't fiddled with them, was just wondering.
kr11zzz31
09-08-2011 07:39 PM
waterdogzx
05-14-2003 06:56 PM
pugliellidude
12-16-2002 03:12 PM
