Exhaust advice needed...
Old 05-23-2002 | 10:52 PM
ZenArcher's Avatar
Re: exhaust advice
If you have a turbo you should already have 2.5" pipes. If you just want a good sound try Magna-Flow. If you wanted performance I'd recommend something else but from your post it seems like a "throaty" sound is all you're after. I wouldn't worry about losing low end torque. If you have a turbo low end torque is kind of a non-issue.
ZenArcher
Old 05-24-2002 | 11:33 PM
ZenArcher's Avatar
Re: exhaust advice
Here is what I did on my 85t:
3" aluminized http://www.certifiedmuffler.com/ dp $175.
3" hi-flow cat from mufflerdeals@aol.com $70.
3" cat-back pipes from http://www.certifiedmuffler.com/ $170.
3" round Dynomax muffler $60. - $25. rebate $35.
That's pretty close to your $400. target
This is a strictly high performance exhaust and so obviously not for everyone due to the sound level but if you want your turbo to perform to it's highest capability (which isn't much honestly) it's the way to go. If you can get away with it, there is a 3" test pipe available from mufflerdeals but it will increase the dB level. HKS makes a catback but it is around 2.5" and prices vary from about $350. on up depending on where you buy.
ZenArcher
BackHouseZ
07-12-2008 04:47 PM
tyyr
08-20-2004 01:54 AM
rebelz12
04-12-2003 07:12 PM
Beaker
09-16-2002 04:49 PM
rob280ZXTurbo
08-27-2001 01:28 PM
Quick Reply: Exhaust advice needed...
