Have a write up for a 4 wheel lug mod to a 5 lug?
Does anybody have the write up or can post the thread for an 1985 300zx 5 wheel lug mod from a 4 wheel lug including the brake calipers? Thanks.
I used Google for you and found this page as the first result.
http://z31.com/mods/
87-89 front hubs, rotors, and calipers bolt right on to any 84-86 strut.
It doesn't mention the turbo 5 lug in prior years but I would bet it is the same. I have some 1987 Z31 struts for sale.
WOW! Appreciate that! will that work for the rear as well or am i better swapping out the whole rear suspension and going with one off a 88-89 rear control arm and all? How much ya asking for those struts?
If you read the link above it mentions the rear for 1987-89 doesn't bolt on, but the whole a-arm with brakes will bolt on. I would conclude that the 1984-86 5-lug does bolt on by the way it is described.
I am asking $75 for both complete struts with brakes.
http://www.bleachgarage.com/sale.html
I could include just the hubs, rotors, and calipers for you to save a lot on shipping.
well i was gonna go for the whole thing ya have there minus the rotors. the rotors i was gonna get from irotors. how much will that run me bro? by the way whats the condition of those wheel studs? just wondering it really dont matter. Just wanna have everything ready so i can slap them on. Thanks bro.
I just wanna make sure i got this correct. I can take the whole front strut assembly off an 87-89 turbo with the 5 lug pattern and bolt that right into my 85 NA with no problem? Now on the rear control arm I can easily bolt on one from an 87-89 as well right on to my 85. Now here is a question that has been confusing me a bit. On the z31.com it stated that I may need to replace the half shaft depending on the rear control arm but i also will have the porblem of worrying about an offset. I have an 85 NA, so is that meaning I need to get a rear arm from the 87-89NA to fit my 85NA so that the half shaft matches right up or can i replace the half shaft to fit it, or do i need to go another route to connect it? I was going to get the rear control arms off an 89 turbo from a wrecking yard and slap them on but i'm worried that the half shaft from my 85NA will not match up to the rear control arm of the 89 turbo. I know this is small cookies for ya but bare with me I wanna learn how to do this on my own. Ever since i left the marines, life is not that great with this recession especially for a wounded combat veteran. Good work is hard to find and tight on a budget. I would like to get this right every bit of the way. Thanks.
Turbo86
07-27-2006 05:38 PM
