Having problems with 1990 300zx n/a, Vids inside....Please help
My issue started happening a few weeks after I purchased the car. Only put about 300 miles on it and then the issue occurred. Please help.
First vid is a sound coming from my passenger side.
http://www.youtube.com/watch?v=eLFMQ0p5has
Second Vid is a flapping type sound when the car is in gear and when the RPM'S hit 2000k-2500k. Above 2500k the sound goes away. In the vid you can hear me rev up the car when it's in neutral and you'll notice that it doesn't make a sound at all.
http://www.youtube.com/watch?v=ezeQMmnEg6w
One morning I noticed both of these sounds so they both occurred in the same time. What do you think it is?
for the second one, i would look at your fan clutch, check it for play...etc if the fan clutch is good, then i would start checking your belts and the idler pulleys. also when you say it only does it when its in gear, then how did you make that vid?
Originally Posted by willkrom1990
maybe something in the throw out bearing assembly. is it really dependent on being in gear or is it just if the clutch is in?
rtmbp4l
FS: 300ZX (90-96)
13
10-24-2005 01:35 PM
rtmbp4l
FS: 300ZX (90-96)
18
04-09-2005 05:39 PM
nissanzxracer
11-01-2002 08:44 AM
