Heads
Guest
Posts: n/a
Re: Heads
one way you could probubly tell is by lookin at a head gasket from both engines just make sure they are from the same sides you know left or right. and see if they match up completly if not then no you can't . to find out go to your local auto parts store and ask to see them both Ithink they should help ya. Odds are that they won't but who knows. If it does work out let us know.
Guest
Posts: n/a
Re: Heads
Hey thanks I know that the honda guys swap heads a lot and they say if the engine codes match up, it will work. The engine code is the same except for the DE at the end (the whole reason for the swap). I will try to do it since I have machine shop and can fabricate it to fit. Oh I am also mking pillow monts for my car I'll let you all know if they work.
Guest
Posts: n/a
Re: Heads
guys...there is absolutely no doubt to it. No "I think" "I doubt" or anything like that... I know for a 100% fact that it will not fit. If you can bolt one on, I will give you $1000!!!
<font color=blue><h2>Engloid Performance!!!</font></h2>
Guest
Posts: n/a
Re: Heads
disclaimer for Engloid:
And have it work. Cause I could drill holes into the block and have it bolt on, maybe....
http://zbum.nissanpower.com
Guest
Posts: n/a
Re: Heads
Well I was "I think"in it because I hadn't tried it myself. But I was pretty sure it wouldn't. the engines are just too different. But my luck I would have said NO YOU CAN'T and AZ would have said... See how you do it.. then I'd felt like an ***... rotf
