Help! Failed emissions
Re: Help! Failed emissions
make sure you check the vac hoses, and set the timing properly.
try using ngk plugs, not bosch. bosch ones run hotter, and higer heat in the combustion process will drive nox emiisions up.
one way to test the cat, is to take temp readings just before and just after it. coming out of the cat should be about 150 degrees hotter than going in.
