injector recall gone bad
i brought my 86 z into the nissan and my car was running perfect. i was there for the fuel injector recall after i got my new fuel injectors nissan tells me my car wont stay running and they said my ecu is shot now. i cant even drive it out of the dealer ship so they said they didnt screw it up and will not replace it so i cant use my car nissan ****ed my over by doing something to the ecu by installing the new fuel infectors . i fought with them and they will not do anything about it what can be the problem with the installation they did so they can fix it they r idiots i am pissed so if anyone knows what i can do about this problem or what can be done about this cause i dont want this happening to anyone who owns a z31 when they go in for the recall so be aware of this happening please help me im carless and upset over this bullsit with all of this email me djskiiz@aol.com
i would suggest getting it out of that shop by tow truck if you have to and take it somewhere else to have it checked. Then if you find that it was something nissan did wrong you may have a case. Dealeship's usaully want do jack to help you especialy on an older car and your at there mercy when you take one to them. I can think of no reason why it should not run if all they did was swap out injecters, thats a pretty simple task and should not have affected the ecu. I have a 83ZX turbo and I swapped my injecters because I had 2 bad, I ordered 6 new from napa and 3 of the new ones were bad. Napa did not want to believe 3 of 6 new was bad but they had them checked and found out they were. Maybe someone just f**ked something up and this is how they are tring to cover there ***. I definently wouold take it somewhere else................
Rumjoky
01-06-2010 05:48 PM
