Lights Turn on by themselves.
Guest
Posts: n/a
My 86 never did this b4 and all of a sudden the head lights started turning on by themselves. The only way i can turn them off is by unplugging the purple plug under the stearing colum. Ive tried spraying cleaner into the colum where the switching is, and it will work for a few days then the problem will reappear. This is very anoying..
Isham
Isham
Guest
Posts: n/a
Re: Lights Turn on by themselves.
Guest
Posts: n/a
then clean it.
if it weren't broken, it would be working properly, now wouldn't it?
http://zbum.nissanpower.com
You don't necessarily need to lube anything, unless you feel the need to. There is some non conductive "grease" but you won't find it at an auto parts store. Go to an electrical supply shop and ask for some wire lube. They might call it something else, but explain what you need and they'll get it for you. It's not cheap, but it works.
greybeard421
08-12-2013 07:40 PM
87z31turbo
16
10-10-2006 07:09 AM
mattduskater
14
02-03-2005 08:09 PM
