Misfire Under Load When Warm Up
88 Z31 Turbo Shiro, been chasing this weird misfire issue. Starts and idles fine, great throttle response, making the appropriate amount of boost and vacuum I think. However, when you drive it for 10-15 minutes and get it warm, it develops an extremely bad misfire under load and a slight misfire at idle.
Only theory other than compression I have right now is heat soak to the charge pipe (previous owner installed an aftermarket one) or induction system,causing a misfire under boost when warm.
Any of you guys have any ideas or advice on what to check next?
- FPR is good
- Tested the MAF with the procedure on XenonZCar and it tested good
- EGR, IACV, CSV have been deleted
- New CHTS (relocated)
- New vacuum lines
Fourplants
02-19-2012 07:41 PM
