Muffler
Guest
Posts: n/a
Re: Muffler
You aren't going to gain much, if anything by just replacing the muffler. You still have 10 other feet of pipe for the exaust to travel through. That last foot isn't going to change much.
http://zbum.nissanpower.com
Guest
Posts: n/a
Re: Muffler
What would you recommend for replacing piping on my exhaust system? I'm not sure what size the stock tubing is but I''ve heard sizes from 2 1/4 to 3 inch tubing is recommended. To replace the stock tubing with larger tubing does that require a new catalytic converter?
Guest
Posts: n/a
Re: Muffler
with an NA, unless you are heavily modded, a good 2-1/2" cat back system will give you a little. Add headers and pipe before the cat and you are golden.
with a turbo, the turbo provides all the back pressure you'll need. Go with a full 3" and turn up the boost a little.
