need help
Old 01-03-2004 | 08:07 PM
dr. buddha's Avatar
Z Extreme Guy
need help
ok i need to know if any one knows the diferance betwen these 2 head #
L-v52 5R
L-v52 2R
need to know asap they bouth come off of 84 z31 turbo
Old 01-04-2004 | 05:49 PM
johnZboy's Avatar
Distinquished Guest
I don't think those are part numbers. The numbers were used somehow in the manufacturing process, but not as part numbers.
All of the heads from the vg30e engines in the 84-89 z cars are the same and interchangable, with the exception of the W series engine built late in the 89 production run. Turbo or N/A, they're all the same.
Maybe this will help... Save it, then magnify until you can read it.
[IMG][/IMG]
Old 01-04-2004 | 11:00 PM
dr. buddha's Avatar
Z Extreme Guy
thank you kind sir. that is a relif was not sure.
i did not want to use a head that was difrent then the pasnger side.if it was going to chang copretion or somthing so now i can go fowered with the project.
and i finished the intake manifold its sweet.
Old 01-04-2004 | 11:41 PM
dr. buddha's Avatar
Z Extreme Guy
hay i was wondring were did you get that info from and is there more
Old 01-05-2004 | 04:07 PM
johnZboy's Avatar
Distinquished Guest
Oh yes!!! Complete fiche here.
It's a little difficult to use, but quite helpful.
