New to the Z game.
New to the Z game.
Hey guys the name is TJ. Just got this 1985 300zx turbo with the electronic adjustable suspension. As of right now tomorrow i'm putting some NAPA rear shocks on, the ones on there are clearly bad, and thursday or friday i'm getting a new windshield. Any budget tips to make this car faster or corner better would be greatly apperciated. When i was looking for a car i was looking 240sx's so i don't know a whole lot about this car.
How do you post an image?
Clean the connectors for the maf, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
Replace outer tie rod ends, and ball joints. replace the bushings with poly (don't forget to lube them as directed unless you like squeaky things). New shocks. all those things will make you think you are driving a diffent car. doing them piece meal is a waste you won't see a great improvement until you do the complete job. Rear bushings nice too but more work and you won't notice as great an improvement. Rear shocks also because if the fronts are gone so are the rears. if car squats when you jump on the gas the rears are gone. If you have the electro adjustable shocks they are DEFINITELY GONE.
there is a start. if you can't fit the shocks you need to find an n/a car at the junk yard and take the mounting plates so you can fit after market shocks. I'd go with tokico or bilstein rather than NAPA
