Radio Antenna
Guest
Posts: n/a
Radio Antenna
Hi all. Maybe some of you more experienced owners can help me out with this. My antenna doesn't seem to be going up or down. I just tested the motor and it works fine. Im thinking (more like hoping) its the switch. My question is...is it common for the switch to go out...or am i gonna have to buy knee pads and sort through my wiring?
Guest
Posts: n/a
Guest
Posts: n/a
How'd you find that??????
Besides the antenna mast really isn't the problem. I tested it out using a battery...the motor and mast are fine. Im attempting to change the switch.
I guess the question i really wanted to ask is if this model of 300zx has a chronic Antenna problem related to wiring.
Thanks for the reply tho.
Guest
Posts: n/a
no. the antenna mast on the 300ZX is the typical piece that breaks.
did someone install an aftermarket stereo? if so, then that's a good indication that the installer had no idea what they were doing. Or they used crappy connectors and the connector fell off and the wire shorted or something.
Guest
Posts: n/a
since you have the factory radio, the switch is to put the antenna in the half mast position instead of all the way up.
In the "on" or up position, the antenna is supposed to go all the way up.
In the "off" or down position, the antenna only goes to a halfway point.
Do this:
turn radio on.
put antenna with a helper, ask them to turn the switch on an off.
listen for the motor.
if you hear the motor, it's the antenna mast.
if you don't hear the motor, make sure 12V is getting to the antenna on two different wires, then start testing the wires behind the stereo.
Do this:
turn radio on.
Guest
Posts: n/a
Just fixed mine
I had the same problem with mine. It was the mast. It is really easy to remove the broken one. Took me about 20 mins total. I would suggest MAKING sure that the mast isn't broken, as mine was cut in half. So it would only go up a little. Just my two cents.
Guest
Posts: n/a
Haha crap...i replied to one of your threads regarding this issue as well.
Im pretty sure the mast is working. I yanked out the motor and hook the damn thing up directly to a battery. The mast shot out and started knocking things down and what not. I even got a new switch..no go. AZ-Z Bum said that i should test the wires behind the switch and did that. I got 12V coming out of 2 wires at the plug that goes into the motor, but the damn thing still doesn't work. Suggestions anyone?
Also..should i test the plug for the switch? Wat kind of readings should i get there. Also does it matter wat two wires gives me a reading of 12V?
Guest
Posts: n/a
I noticed on my antenna motor assembly that there was this "black box". I believe that is the controller for the half up and full up for the switch. I would test the wires going into this, and then test the wires coming out going to the motor. When you tested the motor by hooking it up to the battery did you use the black box or just straight to the motor? If you did straight wires, then try with the box.
Not to sound redundant, but did you take the motor assembly apart and see with your eyes that the mast is fine? That is pretty easy to do, just one nut (6mm). Then becareful, it will just explode in your hands. (At least I found all the parts)
Guest
Posts: n/a
Well i never took it apart. I assumed since the mast came out that everything was ok. I'll yank it out again this weekend and take a look at the mast..im almost certain the mast is fine but i'll look anyway. Could it possibly be some problem with the connectors? Or maybe bad wiring within the motor somewhere...
Eh crap..maybe i'll just get one of those crappy fixed antennas and eliminate this problem altogether.
LikeZcars
05-29-2011 12:36 AM
