Roasting
Roasting
Alright ive had my 86 na on the road since march, and for some odd reason at all points in time hot air comes out of my vents. Once im running hot it does it worse , I figured it was a vacuum leak, but i cant find the damn thing. Im at a loss of figuring it out and figured i would ask for some help lol
Please and Thanks Zach
No. I really didnt think that it could go bad. and thanks for the input.
See but that still doesnt answer why air only comes out my defrosters no matter what i have it selected as?
Check all the vacuum lines from the vacuum canister to the firewall. Also all vacuum lines on the heater valve on the right rear of the engine.
Alright i think my vacuum tank is bad but i ran a new vacuum to the water **** and after a few pumps of the gas it has enough to shut it, for the interior actuators the line running to them is bad on dash side and haven't had time to pull the dash and find it/.
Wow, you're brave. I've never pulled a dash out of any car I was going to have to put it back in, and hope I never have to. I'm sure that's a real bitch of a job.
I still doubt it would ever go back together right, without having to remove it again and fix something, or reroute something that got pinched in the process. It's a horrible car to have to work inside of, with so limited space!
