rpm hang
Old 12-18-2011 | 07:13 AM
mossyoak.1988's Avatar
Exclamation rpm hang
ok well before the rpm would hang when shifting before i changed my tps unless i moved my tps around and it would stop then it would just surge at idle so i replaced my tps yesterday and it dont have the surging anymore now it just has the hang no matter where i move it to any ideas?
Old 12-18-2011 | 07:39 PM
Flacster's Avatar
What are you talking about? Your going to need to rephrase your question.
Old 12-19-2011 | 09:43 AM
alexbre00's Avatar
so your saying the rpm stays in place when u push the clutch in?
Old 12-19-2011 | 12:16 PM
basically ya when im driving and shifting from gear to gear it just stays there and usually even goes higher in rpm when clutch is pushed in. it doesnt do it when cold only after it warmed up. i was thinking maybe idle control valve doing it but i dont want to go spend 150 on icv if its not the problem.
Old 12-19-2011 | 12:32 PM
Have you tried pulling the ecu codes?
Old 12-19-2011 | 04:26 PM
how would i pull the ecu codes? would i have to go to the dealer or could i just go to auto zone or oreilly.
Old 12-19-2011 | 04:31 PM
Neither... go to Google, find steps, and then perform steps.
http://www.nissanforums.com/z31-300z...z31-codes.html
Old 12-19-2011 | 04:49 PM
ok thank you. i will have to do that tomorrow cause its pouring rain here and it sais that on the turbo models you have to drive them and try to keep my car out of the rain. i will let you guys know the results in the next couple days. thanks again for the help
dtmpower
07-03-2011 12:07 AM
daddy Z
06-06-2006 02:03 PM
pearly whites
07-12-2004 09:55 AM
Quick Reply: rpm hang
